Originally posted by wolfman
welp...the gto deal fell thru :o(
Aint it great to own another import!!!!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
Originally posted by Performin NormanKen, here is my friend Lacy and her GTO.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
z28_xxx
Originally posted by z28_xxxWhen do the "500 HP" rice stickers go on?
Congrats. The shifter is better for '05 but still leaves a lot on the table. B&M and GMM Ripshift are available. I even modified an SLP and had an adapter made for the stick...worked as good as the B&M. I now have a Ripshift.
You can get even more info from the DIC if you hold both the Mode/Set buttons at the same time while starting the car. VIN, computer program, fuel program, coolant temp, trouble codes, etc. Not in the book but it works. After scrolling through all of it, don't freak at the end when the gauges go max and every light comes on. Its a test of the gauges.
The Magnaflow cat back on the SAP cars sounds very nice.
Funny you should say high speed driving is not as stable. Many others, around the world, say its extremely stable. Moreso than Corvettes and Vipers, probably because of sound with those cars. But I've noticed its not as "jumpy" at speed than an F-Body.
Bolt pattern for the wheels 5x120 whereas GM uses 5x120.65. You can use F-Body wheels with no problem, at least the 16". SLP uses 16" Firebird wheels for the track. Many have used other GM wheels but you have to pay attention to offset. The 17" wheels just stick out too much. I have pictures of my old WS6 wheels on a GTO and it looks good but won't work. BMW 3 series wheels work well, except the M3. Offset is too great.
Congrats on the new ride.Rob
04 GTO
congratulation wolf, and please tell GM if they listen to their costumers,they will sell lot more cars look at GTO 04 compare to GTO 05. look awesome GTO you have there wolf i love the fornt end did you order special for that bro ?2001 Trans Am WS6 M6
Originally posted by 1sickbirdcongratulation wolf, and please tell GM if they listen to their costumers,they will sell lot more cars look at GTO 04 compare to GTO 05. look awesome GTO you have there wolf i love the fornt end did you order special for that bro ?Rob
04 GTO
how is 06 GTO looks like ? totaly different ?2001 Trans Am WS6 M6
rob.. i really have not had it a high speeds...my comment was based on lane changes at 65mph...which, as you know, ain't much to compare on. im sure ill be finding out its attributes.
1sickbird, no..thats the dealer only installed appearance package for the car from gm........ thats what sold me on the looks...the engine already had sold me...hahahahaha
wont be doing much switching of tires or exhausts and stuff for a while. need the money channeled into rescue. doubt ill be doing very many mods....
its has the upgraded cat back on it from gm. sounds real good.... like 2-on-the-left but a little quieter and much more lower rumble, believe it or not... i really kinda like it. mary heard me pull up in the driveway from the dealers with the garage doors shut. she said it was a real low thunder sound....
that brought a grin!
