I'm sure y'all have heard it a thousand times, so here's 1,001.
My left turn signal stays solid, while the right one works. I replaced the flasher but obivously nothing is fixed. I can blink it manually but quite honestly, its becoming a PITA. As I see, there are two bulbs in each signal, only one works in both the front and rear, driver's side signal. Would my best bet be to replace the bulbs? If so, how hard is it to get to the rear socket? I've popped the tail light unit out but it seems difficult to take out. I was also thinking that it could possibly be a wiring issue. If so, what should I do/look for? There are no cracks or leaks (I was only able to check the front one). The car is a 95' Firebird.
