My TA needs a new starter. Has anyone put one in and i was wondering how tough it might be and how long it will take.
need new starter
The stock Y-pipe will interfere with starter removal. Not clear whether you still have it.
You can get an LT4 starter for less $$$ than a stock LT1 starter, and its supposed to weigh less. I bought a CVR Pro-Torque starter for $150 from JEG's (although they don't show that part # in their catalog any more). It has a mount that allows the entire starter assembly to be rotated to increase clearance to headers, etc.Fred
Make sure the battery is disconnected. From there, its just nuts and bolts. You'll probably have to drop the y pipe, which can be a PITA if the bolts are rusty. Then there are 2 bolts holding the starter to the block, which face the ground. Remove em. Then take the nuts off the terminals that attach the wires to the starter solenoid. Reverse the procedure for the install.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
2 Bolts. Y pipe will def. have to be dropped.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
guys what are symptoms of a bad starter?
i have a 95 Lt1 Z28...i turn the key sometimes and the starter does not engage and nothing happens. usually when that happens the second crank is the charm. might need to look for a new one. not looking forward to installing it tho.going to clean my battery terminals today that might help. G Fry33 let me know how the insatll goes. i do have a aftermarket y-pipe but it still will have to come down. might have acces to a lift
i hope
eddie
Could be either the VATS or the column mounted ignition switch. The symptoms of a bad starter is failure to turn over the engine once it engages. When the starter solenoid doesn't "click" and there is no starter activity, that usually points to an electrical problem. Especially when you try it a second time and it works.Originally posted by LoudLT1i turn the key sometimes and the starter does not engage and nothing happens. usually when that happens the second crank is the charm.
I did it without removing the y pipe,
pita
93 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
Ditto that...Originally posted by Joe 1320Could be either the VATS or the column mounted ignition switch. The symptoms of a bad starter is failure to turn over the engine once it engages. When the starter solenoid doesn't "click" and there is no starter activity, that usually points to an electrical problem. Especially when you try it a second time and it works.
IF you turn the key and you don't hear anything...VATs or electrical. If the start is going bad, you'll hear a CLICK. Everytime you turn the ignition it'll click...
My freind put the starter in for me when i was at work in about 35 minutes and he didnt need to drop the y pipe. After the starter went in i was getting the click when the key turns but no turnover. What else can i check or what else could be the problem? alternator and battery are new within the last 6 months also.99 Z28 M6, SS hood, borla muffler
93 TA A4, sold
