A friend of mine has an 03 gt vert auto (its his moms) he was going on and on about how fast it was today and thats was getting on my nerves. I dont want to race him simply because my license are worth more to me than pride. I was just wondering what are the performance values on them and compared to a 96 z a4
96z vs. 03 gt
take him out to the track...but go out there first and practice. . then your license wont suffer....and its all up front and straight forward. call his bluff.Originally posted by 96z28A friend of mine has an 03 gt vert auto (its his moms) he was going on and on about how fast it was today and thats was getting on my nerves. I dont want to race him simply because my license are worth more to me than pride. I was just wondering what are the performance values on them and compared to a 96 z a4
its gonna be close, but drop your rear tires down to 26, pump your front up to 44......and let him have it.......
If you can get a good launch, you'll smack him easy. If not, it'll be close, but you should still be able to beat him. Go to the track and educate him on Bowtie Power
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
does that make a big difference?Originally posted by wolfman
1996 Trans Am WS6
A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
Oh yeah. I'm not too sure what airing up the front will do, but letting some air out of the rears will allow the tires to flew some more on the launch, thus improving traction and giving a better holeshot.Originally posted by redws6does that make a big difference?Steve
Mods
Mods
Mods
i found my old Eagle GSC's hooked up best between 15 & 18 psi. try different pressures until you start hooking up good.Originally posted by wolfman
LOUD2000T/A
'00 Trans Am M6, K&N filter, Airbox Lid, F.A.S.T. LS-X Intake, Stainlessworks offroad y-pipe, Loudmouth catback, Pro 5.0 shifter, Hypertech programming, 17" Torque Thrust II wheels, 12.97@113; '87 Monte Carlo SS; '91 Sonoma V6 4x4.
The Z will win. I've never lost to a 99-04 GT... Especially with an auto.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
My friend's dakota R/T is right there or beating most stock GT's. And he only ran 14.5 last time he went to the track, although he is a little faster now i won't expect it to be by much. Now my car on the other hand, i'm lucky to beat most rice
2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
Billdog350
The Fords are down quite a bit on HP (260 vs your 285) and the convertable will be heavier than your Camaro for sure. I know I just had my 1994 Z28 dynoed and I was putting down 270rwhp and 316 tq on my stock motor with 147k miles. A 2005 Mustang GT pulled in after me and only put down 265hp and 285tq.....
Last I knew, the new GT's are even heavier than last year's body style, so theoretically I should be able to beat him if we're both in stock form.
Also, your buddy's mom's car probably has 235's or something (stock tire width) but your Z should have at least 245's on there (stock). The additional tire width, lower tire pressure, higher hp, lower weight, etc all should add up to a definite win for you unless he's a better driver, gets a better launch, or has had some significant work done to the car while mommy wasn't watching.
Originally posted by Steve93ZOh yeah. I'm not too sure what airing up the front will do, but letting some air out of the rears will allow the tires to flew some more on the launch, thus improving traction and giving a better holeshot.
Higher pressure in the front tires will have lower resistance. slightly smaller tread in the ground.
Ahhhh, gotcha. Thanks for the infoOriginally posted by SteveH95FormulaHigher pressure in the front tires will have lower resistance. slightly smaller tread in the ground.
Steve
Mods
Mods
Mods
Camaro Berlinetta Digital Camaro 202 heads 4 barrel and soon to be headers with 4 inch running back
