--94 LT1 Z28--
ok, i have one aftermarket gauge drawing very little amperage hooked up to the single "ign" tap terminal on my fusepanel. i need to tap it again for a pump which is part of my supercharger oil recirculation circuit. whats an easy way to run 2 or more wires off this fused "ign" tap terminal? thanks
-chris
-chris
for you to use it. That's what I did, used wires that were not doing anything else. But even if you don't have any blank wires, you can still use the ones there, as they wire these cars overkill so that even if there is a surge of power, it will blow the fuse and not burn the wire up.
