My vote is to get an 89 TPI third gen. Best year in my opinion. Last year of MAF, which takes mods better (eg, cam, heads etc.) due to the way it calculates air to fuel. Less PROM work needed due to this also, SD TPI needs a reprogram for everything or it starts to throw codes. TPI is a great street motor, lots of torque, I would stay awya from TBI motors unless you plan on changing the heads soon after you get it as they have swirl ports(bad for High RPM HP). 89 has all the nice body updates of the 90-92 including better adhesives and welding. First year of dual Cat exhaust, and the TPI version has reportedly the best cam ever put in a TPI motor.
3rd gens
my lil tbi raced a LB9 5.0 and kept wit it pretty good. all it has is a rebuild, cam, oil pump, intake manfiold, low temp fan swtich, upgraded ignition(coil, cap, rotor, plugs, wires). cat and a dynomax exhuast. its really powerful for a tbi motor ten again it has a 5spd and soon to be 3.42s out back2009 Honda Civic EX- the daily beater
Originally posted by 88bird5spdmy lil tbi raced a LB9 5.0 and kept wit it pretty good. all it has is a rebuild, cam, oil pump, intake manfiold, low temp fan swtich, upgraded ignition(coil, cap, rotor, plugs, wires). cat and a dynomax exhuast. its really powerful for a tbi motor ten again it has a 5spd and soon to be 3.42s out back1991 Chevy Camaro RS (Is it plum or purple?)
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
Originally posted by Benm109The 2 best things you can do to 305 TBIs is full exhaust and gears. You'll love the 3.42s, I've had mine for about 3 weeks now .
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
