Well I just got my new Power Acoustik stuff for my car and I had the bright idea to attempt to let my boyfriend build me a sub box...I had a fiberglass top for the subs just needed a box to go around it.. Well he measured everything right but the height. We measured it to go on the flat part of the hatch so I could still have my t-tops space. Well we put it in and I'm not very tall and yea I can't see out of the back hatch at all. It's about 2inches too wide for the t-tops space which I was willing to sacrifice, but I dont think I want to now lol..now I'm stuck witha box I can't/don't want anymore..and custom enclosures that allow t-top storage are expensive the one I liked is around 300 and I am def. not gonna let my boyfriend attempt another box for me :-).If anyone knows of any sites with custom enclosures could ya please post a link for me it'd be much appreciated, thanks!
Sub Boxes...just venting a lil
I have been thinking about this for a while. On ebay there was a camaro SS sub holder that replaced the flip lid on the trunk so you could flip it away from the trunk when you needed the space. He wanted 200 I think for it, kind of a bit but a good idea. I dont have a link for you though. There are TONS of sites that will go through making a custom box though. good luck94 Formula Firebird, 355, heads port and polished, cc503 cam, 30# injectors, PCMforless Tune, B&M 2400 stall, K&N CAI, BBK Sorty Headers, Magnaflow Highflow Cat, Borla Catback exhaust with electronic cutout.
Originally posted by Canadian formula funI have been thinking about this for a while. On ebay there was a camaro SS sub holder that replaced the flip lid on the trunk so you could flip it away from the trunk when you needed the space. He wanted 200 I think for it, kind of a bit but a good idea. I dont have a link for you though. There are TONS of sites that will go through making a custom box though. good luck
**Red 98 Trans Am--Flowmaster--MTI Clear Lid--Smooth Bellow--B&M Shift Kit**
**White 98 Dodge Stratus--Daily Driver!**
**RIP Red Firebird 170k**
Well heres a link for a permament 3rd gen one, maybe it can help you a little. You may have to visit a few sites and piece somethin together. I couldn't find one for 4th gens.
http://www.thirdgen.org/newdesign/tech/subwoofer.html94 Formula Firebird, 355, heads port and polished, cc503 cam, 30# injectors, PCMforless Tune, B&M 2400 stall, K&N CAI, BBK Sorty Headers, Magnaflow Highflow Cat, Borla Catback exhaust with electronic cutout.
This is the only one that I have found that will not interfere with the T-top rack.
http://www.crutchfield.com/S-vI5naTt...750&I=236CF10U2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
http://www.subthump.com/acamarottop.html
that is exactly what i want...but they want 275 for it plus shipping and its like 10 day shipping...it looks like a simple design but i dont know anyone with good wood cutting skills lol
i was thinking about gettin two seperate 12' sub boxes and fiberglassing them and puttin the amp in between them and making a fiberglass platform for the amp...but im not sure if it'll work..blahhh i wish i had a non t-top car now lol
This is the one i have http://www.subthump.com/acamarostealth.htm it works great, I only have one 10in sub, and an 1100 watt mono amp, you cant sit in the car with it cranked. I mounted the amp to the area above the gas tank. Hope this helped.95 Trans Am, K&N CAI, LT4 knock module, Flowmaster exhuast, Grant GT steering wheel, Sony head unit w/sub, Autometer Gauges
Originally posted by 99 Fir3bird Chickblahhh i wish i had a non t-top car now lolblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
Originally posted by imwlw83This is the one i have http://www.subthump.com/acamarostealth.htm it works great, I only have one 10in sub, and an 1100 watt mono amp, you cant sit in the car with it cranked. I mounted the amp to the area above the gas tank. Hope this helped.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
While the "t-top box" is good in theory, they didn't do a good job with the manufacturing. Basically all they did was leave a gap. Both tops are resting against each other, and in the event of a crash, they will shatter. Not to mention they are sticking up and probably block rear view. Heck, in high heat situations like down here in the south, they'd probably shatter over a rough bump with them touching each other like that! What they should have done is build the box with 2 slots in it and have the tops slide farther down in the hole. Then you could have 2-10's or 2-12's with both tops slid down so far that all you have sticking up is the latching section. You could even top it off with a velcro adjustable strap to hold the tops down in the box so they wouldn't fly out in a crash.
I have a T-top car, but I never take the tops out. However, because I wanted to keep them functional, I have the JL audio stealthbox (a lot more than $200) and it pounds. Most people think I have 2-10's and not just one. If you want 2 subs and you want to keep the t-top holders, you need to go with the dual stealth boxes. It's gonna cost a ton, but I would not trust that "t-top box" with my high dollar t-tops.
The way my car is right now, I can do one of two things. I have the stealthbox mounted in the drivers cubby. Then the t-top holders. On the right side I have a 50 disc (not a misprint) CD changer and a 15 pound bottle in the spare tire well. If I want more bass, I slide in the box I made for my car for 3-10's, and it fits in the t-top well, flush against the drivers cubby, and up against the door of the 50 disc changer. It takes 10 minutes to go from 3-10's with the tops in to 1-10" with the tops out. I also have my 1200/5 Directed amp mounted on the package tray along with 2-1 farad caps behind a plexiglass windowed MDF display board, with the amp elevated for better cooling. I cover the amp rack with the factory flip panel so the sunlight stays off of it (and wandering eyes can't see my stuff)."No, officer, that bottle is my onboard Halon system"
just a thought -i dont know if break in's are very bad where you are from-but you might not want to put the amp there--if people can see it walking by then its more likely to be broken in to-im re doing mine and one of the main priorities is not being able to see it unless im showing it to youBlack '96 Z28, loudmouth exhaust, Mac mid length headers, crane cams powermax 104227 cam, crane 1.6rr,'s, springs, lifters and pushrods. MSD distributor, slp ultra z hood with air box, bbk 52mm throttle body, march underdrive pulleys, hpp+, 1le sway bars, spohn LCA's and relo brackets, Spohn SFC's, adj panhard bar, bilstein shocks, H&R springs, strut tower brace...Audio-Alpine head unit, MB Quart 6.5" component in the front and 6.5" Boston in the rear w Alpine 75x4 amp, Alpine Type-X 12 in the trunk w/ alpine 1000w amp
i dont have a problem with breakins in our area, the TA stays at home most of the time, and home is really secure. But just to make me feel better, i left the little flapper lid that the t-tops go under in the car, and if i have to park at the mall or places like that, i flip it up before i leave the house and it does a really nice job in covering the amp. The windows are tinted at 5% and you cant really see anything in there. Works out great, but you are right it could be a problem in your area, so keep that in mind when you do your equipment placement
Here's an idea that should allow you to still use your factory T-top holders plus add in the subs. Get one of these for whatever size of subs you wanna add, 10s or 12s,...
and leave slack on the wiring to the actual subs. This is actually 2 enclosures built into a bracket that fits on the back. Then, then you need to get to the holders, simply lift the bracket and viola. You can get them at Crutchfield. Hope this helps.Steve
87 GN - its just a 6...Mods
93 Z28 - slightly tweakedMods
That is a Q-form box, and if I remember correctly, it requires the removal of the t-top holders. Regardless, there is no way you can put the tops in with that box in place. It looks good, but the subs are recessed in that box, so all the air comes from underneath. That won't work for what she wants."No, officer, that bottle is my onboard Halon system"
