What size Gauges?
  • What size Gauges?
    Hi everyone i want to put some gauges in my 97' Formula. I would like to install them in the heater vents. What size do i need and what gauges should i go with?
    "You can't piss on what you can't catch."
    The 2-5/8" gauges fit just right in the A/C vents.
    I have nitrous pressure, fuel pressure and oil pressure in the vents, and tranny temp and oil temp on the A-pillar.
      yeap the 2 5/8 gauges, you will love the mod.
      95 Trans Am, K&N CAI, LT4 knock module, Flowmaster exhuast, Grant GT steering wheel, Sony head unit w/sub, Autometer Gauges
        Thanx for all the help guys.
          Just curious but how did you mount them Fred?
          1997 6-spd WS6 Trans Am
            When you pull the vent "eyeball" out, the resulting opening is exactly the correct size to FIRMLY hold the gauges in place. You make all your connections, then push them into the hole.
            In fact, it can be sort of hard getting the 1st gauge back out of the hole. Both my nitrous pressure gauge and the oil pressure gauge have an -AN hose that is routed through a hole I drilled in the ducting. The wires for the lights and the electric fuel pressure gauge pass through the same hole.
            They will stay there, mounted solidly.
              I can vouge for this as well
                I put a bronze spacer ring behind mine to make them stand alittle straighter, i had to use the gauge mount hardware but it worked out great.
