What kind of mileage did you guys get with a new tune for a *relatively* stock setup? On pure city driving with terrible stoplights, I got 11.1 mpg with a new PCMFORLESS tune. That was my first all-city run...with 80% city, 20% freeway, I got 14 mpg previously. I don't really care about the actual mileage, just want to make sure it's tuned correctly and/or running right...11 seems a bit low considering the tune was supposed to lean out the rich mixture a bit (is that right?) Thanks in advance.
mileage on new tune?
I got 17.6 mpg all city driving like grandma. Actually my normal driving has been around 15 and that includes several WOT to speed limit.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I seemed to be getting lower and lower gas mileage so I checked it and it was around 9-10mpg
I took it into the shop and have been trying to fix it since, atm I am up to 17-18mpg and atm I am testing my injectors to hopefuly totaly fix the problem.
It could be that you have something else wrong and you just need to fix it.94 Formula Firebird, 355, heads port and polished, cc503 cam, 30# injectors, PCMforless Tune, B&M 2400 stall, K&N CAI, BBK Sorty Headers, Magnaflow Highflow Cat, Borla Catback exhaust with electronic cutout.
I would shoot myself if I was getting the MPGs you guys are...I'm perfectly fine with my 19 city MPGs and 26 highway.
I love stock...hahaha, not really.
Hey man, didn't they say they recommend running the ported MAF ends? That might be part of the problem, since it sounds like they programmed for more coming in than actually is. Worth a shot I supposeSteve
79 FSJ - most expensive AMC Jeep everMods
87 GN - its just a 6...Mods
93 Z28 - slightly tweakedMods
Originally posted by 88bird5spdeh i get 8mpg and thats 70% city, 30% highway.
I think I average about 14.5 mpg city....I hate gasblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
That does seam a bit low. Does the car seem to be running alright? Isn't most of whats done in a tune is work out power enrichment mode which is for WOT? When was your last tune up (plugs, wires, 02's, fuel filter, opti ok?)?1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Originally posted by 94 formulaThat does seam a bit low. Does the car seem to be running alright? Isn't most of whats done in a tune is work out power enrichment mode which is for WOT? When was your last tune up (plugs, wires, 02's, fuel filter, opti ok?)?Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
SOLD- Good riddance!
Originally posted by NightrageHow much would it cost to have a mechanic change my oxygen sensors? I need to do a tune up badly. I just spent $36 to fill up my gas tank.
Speaking of plugs, have you checked your current ones Craig? The ones that were done after the vandalism may be shot now. I've still got that set sittin' here tooSteve
I'm with Steve 02's aren't that bad but doing plugs is whats going to be hard or costly at a garage. My 02's were like $70 or $80 from Sam Taylor. If the garage would let you give them the new 02's and install them it shouldn't be more than $20 in labor or you could do it yourself. Just climb under there with a wrench unhook the connector and unscrew them. Depending on how long they've been in there they may be seized in there a little and some pb blaster and a little heat should do the trick.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Thanks for the replies guys...
Everything is brand new, including the whole fuel system, ignition system, and some emissions related components.
Steve is right though...Bryan mentioned to me that the tune was for ported MAF ends and I switched back to stock for now. I will switch them out and see. I think it had a lot to do with my driving style that fuel run.
Also, my commute is roughly 3.9 miles one way. It takes me 15 minutes to get to work...so I guess that's about a 15 mph average...and I'm usually around 50 mph between lights. Maybe it's the constant excessive acceleration and sitting at lights?94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Also, my commute is roughly 3.9 miles one way. It takes me 15 minutes to get to work...so I guess that's about a 15 mph average...and I'm usually around 50 mph between lights. Maybe it's the constant excessive acceleration and sitting at lights?Steve
Originally posted by Steve93Z"Excessive" acceleration? That's what we're calling it now, huh? lol..."Excessive Acceleration" is definetly going to put a damper on your gas milage. Next time you take it on a trip and get a tank on mainly highway milage check it then and compare it to what you had before that'll give you a better idea.
