SLP website only shows it for a LS1 car. This should work fine on a LT1 car with LT Headers and Y-Pipe, correct? I got a flat the other day and it knocked a hole in my Borla. Anyone else ever experience Dayton tires gettin flats often? This is my second blowout in less than three months. I check my pressure often.
Question about Loudmouth II
That is the same setup I am going with and yes it will work all you need is the 96-97 slp LM install kit which runs $32.00 plus shipping @ Lmperformance.com. All the kit consists of is a few brackets which allow you to mount the LM on your car because it was designed for the LS1 cars. I just bought my LM II and it should be going on in about a week so I will let you know how it goes and I will try to snap a few pics. In the next few months I am gonna pick up some coated pacesetter LT's and y-pipe and from the research I have done their will not be a problem with this setup.1997 6-spd WS6 Trans Am
Here are the brackets
http://www.lmperformance.com/1623/2.html
Heres the exhaust
http://www.lmperformance.com/5574/2.html
So far with shipping these are the best prices I have found.1997 6-spd WS6 Trans Am
Dayton tires suk.
trust me.
Yep, I am planning on gettin new wheels in the next month or so, I think I will go with Nittos. The only reason I replaced it with another Dayton was b/c it was still covered. Pissed me off when I found the hole in my Borla.Originally posted by wolfmanDayton tires suk.
trust me.Life is not a journey to the grave with the intention of arriving in a well preserved body, but rather to skid in broadside thoroughly used up and totally worn out, loudly proclaiming......WOW WHAT A RIDE!!!
BFG's would be a good choice too. Any reason you're not gonna call Borla and see if you can have the pipe replaced? Yes, the LM 2 will fit without a problem. It is listed only under the LS1 cars since it was made for the LS1 cars. Hence the reason the kits are listed for the LT1 cars, as Dr. Bob. pointed out. They sound close to the same (assuming you've run Borla with anything but the closed plate). If, at any time, the LM 2 muffler becomes to bulky for what you wanna do (e.g. Spohn torque arm with 2 driveshaft loops), you can replace it with a Sweet Thunder muffler, as it is the same outer diamter as the pipes, still a straight-through muffler and still sounds good. Good luck on your new (or old lol) set of pipesOriginally posted by RyanB58Yep, I am planning on gettin new wheels in the next month or so, I think I will go with Nittos. The only reason I replaced it with another Dayton was b/c it was still covered. Pissed me off when I found the hole in my Borla.
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
I guess I could call them and see if they will replace it. I doubt it, because you can clearly tell it was damages from a shreded tire. I did call Dayton when I was upset about what happened, I should have made them replace it. I like the BFGs also, but arent they a bit more pricey than Nittos? Just curious, when the time comes I will research it more.Life is not a journey to the grave with the intention of arriving in a well preserved body, but rather to skid in broadside thoroughly used up and totally worn out, loudly proclaiming......WOW WHAT A RIDE!!!
Well, worst case scenario, if Dayton won't cover it (even though they should), you could call Borla and see how much it costs for the pipe. I doubt they'll replace it for free, but it may be cheaper to have the piece replaced than replacing the whole system...unless you've wanted to anyways lol.Originally posted by RyanB58I guess I could call them and see if they will replace it. I doubt it, because you can clearly tell it was damages from a shreded tire. I did call Dayton when I was upset about what happened, I should have made them replace it. I like the BFGs also, but arent they a bit more pricey than Nittos? Just curious, when the time comes I will research it more.
As for the tires, the Nitto 555 Extreme Performance is $158 at Discount Tire Direct while the BFG g-Force T/A KDW is $173 at Tire Rack, both in a 275/40/17. While the BFG's are $15 more/tire, I've been told you do get what you pay for. Just my 0.02
Steve
Mods
Mods
Mods
Thanks guys. As for the tires, I will prolly go with the BFGs b/c my dad has a buddy witha Auto Tire Store. Not sure what I will do with the exhaust, prolly get the LM just cuz my Borla is gettin old and I would really like to try the LM2. Thanks again!!!Life is not a journey to the grave with the intention of arriving in a well preserved body, but rather to skid in broadside thoroughly used up and totally worn out, loudly proclaiming......WOW WHAT A RIDE!!!
Good deal man, lemme know how you like the BFGs. Also, post a sound clip of the LM 2 if you can, kinda interested in how it sounds. Take care manOriginally posted by RyanB58Thanks guys. As for the tires, I will prolly go with the BFGs b/c my dad has a buddy witha Auto Tire Store. Not sure what I will do with the exhaust, prolly get the LM just cuz my Borla is gettin old and I would really like to try the LM2. Thanks again!!!
Steve
Mods
Mods
Mods
I like the sound of my borla, but I am just as curious about the LM2, so I will certainly put up a clip.Originally posted by Steve93ZGood deal man, lemme know how you like the BFGs. Also, post a sound clip of the LM 2 if you can, kinda interested in how it sounds. Take care man
