louvres on '86 T/A
  • louvres on '86 T/A
    I'll post a picture of what I mean at the end of the post but I was thinking of putting a cowl scoop on (non-functional) becuase I think they look really nice but I don't have the money to buy an all new hood. Anyway the one I was thinking of buying would basically run the length of the hood, in doing so, it would cover the louvres on the front. Would it be ok to cover these, or do they need to open to let air into the engine compartment?
    They are mostly covered on the underside of the hood except for some small holes, but I wanted to make sure before doing anything. Also what is a good bonding agent to use to attatch the scoop to the hood?
    -Dan
    Shouldn't be a problem. They let some heat out, but not enough to cause overheating if covered. Also, If you are covering the louvers with the cowl-induction scoop, the louvers should vent into the hollow part of the scoop and vent out by the windshield.
      Good deal. That's what I was hoping, thanks for the info.
      -Dan
        The only problem with that is that air is coming in from the cowl area not out...
        Greg W. in West Michigan
        1983 Z28-Parts car- *Sold*
        1984 Z28-305 HO Auto *Sold*
        1986 Camaro-V-6 5Spd *Sold*
        1984 Camaro-V-6 Auto *Sold*
        <Motor out
          For the most part, yes. But what little heat which is relieved from the louvers will mix with the cool air coming in from the cowl. If anything, it may even run slightly cooler.
            Unless I could go and get it installed so it would be functional, but at that point it might be cheaper just to buy a new hood....thoughts?
            -Dan
              You might be able to find one used. Check eBay and post something in the buy/sell message board of this forum.
                dude your car is clean for an 86. Clean for any 3rd gen for that matter.
                1999 Ram Air Trans Am. M6
                SFC( not sure what kind), drilled/slotted rotors, K&N air filter, all free mods, 3" Borla cat back exaust, electric exaust cut out, NGK spark plugs, royal purple motor oil, and Zaino .Maybe more. I find more stuff done to it everytime I look at it.
                  thanks man, I think it was repainted a little while before I bought it, but I do my best to keep it in shape....gotta get my hands on some zaino...
                  -Dan
