Is the air dam that piece that blocks the underside of the car in front? If so, since mine is hanging down on one side, would that make the engine not cool as much as it used to on the freeway?
Ignorant ??
Check this out brand new good price so far http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW1993 TA SOLD
A good quick fix is to use a flat bracket and a couple small self-tapping machine screws. As long as it's not noticable, it will hold better than duct tape until you get a new air dam.SOLD: 2002 Trans Am WS.6 - Black on Black - 6 Speed
clean the bonding surfaces real good...cause believe it or not..super glue works... i did it on sport bike air damn once. it held at 165mph
One of the local morons in town took his off as part of his weight reduction after he beefed up his engine. Poor guy can't figure out why it keeps getting hot.1999 Ram Air Trans Am. M6
SFC( not sure what kind), drilled/slotted rotors, K&N air filter, all free mods, 3" Borla cat back exaust, electric exaust cut out, NGK spark plugs, royal purple motor oil, and Zaino .Maybe more. I find more stuff done to it everytime I look at it.
On a closed circuit course, I assume...Originally posted by wolfmanclean the bonding surfaces real good...cause believe it or not..super glue works... i did it on sport bike air damn once. it held at 165mph
Temporary fix eh????? I think it's time to ghetto rig something here.Originally posted by braindeadracefanCalled the dealer, and it's not much more than the one on ebay (thanks for that, btw). Gotta order it though, so does anyone have any ideas for a temporary fix until I get it? I gotta drive out of town.
If it were me, I probably wouldn't drive my car. If it was absolutely inevitable....hmmmm.
1) Go to a junk yard and get yourself an air dam off another f-body.
2) Cut a piece of sheet metal and get it up there one of the many ways that was already mentioned
3) Cut a piece of heavy duty plastic and do the same as you would with the sheet metal.
And that's about all I'm thinking right now. I would probably try and find a way to zip tie it or screw it on there somehow just to make sure it doesn't fall off again.
Good luckblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
goodyear 5 mile oval, banked, san angelo, tx. 1986.Originally posted by 02 WS6On a closed circuit course, I assume...
yamaha factory modified fj1200
rider: wolfman
radar verified.
never again.
