I was just driving around and I noticed that when im in third gear at around 2000 - 2500 rpm and im just coasting at a constant 2000 rpm, not put my foot on the gas or anything but im not losing RPMS, I have noticed that the car seems like its gunna stall. When i put gas into it, its fine. But isnt 2000 - 2500 in 3rd gear a little strange for the car to stall? Anyone know what the cause might be? Or is it normal and im over reacting
3rd gear stalling >>>?
darkz711Tags: None
do you mean its hesitating? or is it actually coughing out and dying on you?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
darkz711
hesitating, like it feels like its dragging its feet. Its not coughing on me and dying like it would if i were in first gear and stalledOriginally posted by N20LT4Birddo you mean its hesitating? or is it actually coughing out and dying on you?
