forgive me f-body for i have sinned
  • #16
    With 89K miles on the car, I would also replace your water pump and install new wires too. If your current water pump starts leaking sometime soon, guess what will get wet again.....the NEW Opti.
    2000 Camaro SS..........6 speed triple black
    • #17
      It took 2 days for mine to dry out.
      Kbddsfc,B&M Ripper,Ws6 Rims,Hotchkiss Stb,Bmr Lca,Gwphr,Strange 4:10's,LPEds,Borla,AS&M Headers,RT cat,Powerslot rotors,Hawk Pads R/Pf pads Fr,Mba shift knob,Slp Hood&Airbox,Holley Powershot filter,Fernco mod, Lt4km,Firebat decals,T/A Girdle,HPP.160stat,Bilstein shocks,Z06 Brakes,AFS ZR1's,GSD3's.
      • #18
        Originally posted by bigtow
        i tried the hair drier and it fired up but run very rough so i tryed to let it warm up but it made no differance when it hit 220 the miss got worse then it cut out again so i have desided to leave it till i can get a new opti fitted ...
        Like the other guy said, give it a couple days to dry out. let it idle a while in the driveway, too.
        ps does any one know the part # for taylor plug wires?
        A lot of guys use them, but a lot of guys have trouble with them as well. All you need is ignition wire trouble. Get yourself some Magnecores, Accells, Mallorys, or some Moroso Blue Max's.
        • #19
          i dont know much about the opti but u said u ordered 1.... did u get a stock replacement? cuz ive seen that the msd opti is half the price, and wouldnt it be better than a stock one? but i have noticed that no1 ever talks about it? is it any good?
          1967 Camaro "Project"
          1972 Chevelle "454"
          1979 Trans Am "Project Ls-1"
          • #20
            the opti may not be bad, it just cant see. you could try cleaning the acutal sensor lens before using the new one. it may seem like a lot to do but you did say you wanted to save $.
            • #21
              i think the msd part is only the cap and rotor not the whole unit
              • #22
                quote"With 89K miles on the car, I would also replace your water pump and install new wires too. If your current water pump starts leaking sometime soon, guess what will get wet again.....the NEW Opti. "end quote
                i may as wel change the whole lot opti and water pump as thay are as far as i know are the original parts from 93 and the car has go nearly 90 k on the clock so i think it,s time for some prevntive maintanice
