Has anyone heard of a company that makes an intercooler or intercooler kit for the powerdyne V6 supercharger? I have heard of shops that will custom fabricate intercoolers, but I would really rather get a intercooler specially made for the powerdyne supercharger. Any information would be greatly appriciated.
intercoolers...???...
1999 camaro v6 bright red with pacesetter headers, custom fab catback, high flow cat, ram air intake, corbeau racing seats and 5-point harnesses, b&m short shifter, 10" wide rubber, kenny brown subframe connectors, koni single adjustable shocks, eibach pro kit springs(1.25" drop), spohn front and rear sway bars, BMR adjustable panhard rod, spohn low control armsTags: None
There is a supercharged v6 thats around here. It's using an front mount intercooler off an old turbo Sabb. It had custom plumbing. If you go used be sure to have the intercooler pressure checked.96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
There aren't intercoolers specific to a particular supercharger model. There are however IC's that are specific to the type of boost (turbo or supercharger) and how much boost at what CFM. Then you need to consider where you want to mount the intercooler and whether you want an air-to-air or air-to-water IC.
Give ProCharger, Pro Turbo Kits, or Spearco a call.
Bingo. You can also bet that if a company puts together a kit for a particular application, it can be done cheaper by doing it yourself. Measure the location you wish to mount it and start checking all other applications and see what fits. For example, a Ford powerstroke intercooler works great on a buick GN.Originally posted by fastTAThere aren't intercoolers specific to a particular supercharger model. There are however IC's that are specific to the type of boost (turbo or supercharger) and how much boost at what CFM. Then you need to consider where you want to mount the intercooler and whether you want an air-to-air or air-to-water IC.
