I recently got my hands on the Helms manuals for my car, and have had a 160 thermostat sitting around since last october
so I feel it is time to install it.
I have been told the trick to refill the antifreeze without trappng air is to disconnect the hose that goes from the engine to the throttle body, fill and run till the disconnected hose begins to spill out and reconnect. ( A friend has ls1edit (infinite license) so I can get him to change th fans)
Any other tricks that might be useful? And should I buy the coolant from GM or the orange stuff and mix with distilled (never changed the fluid since car was delivered)
so I feel it is time to install it. I have been told the trick to refill the antifreeze without trappng air is to disconnect the hose that goes from the engine to the throttle body, fill and run till the disconnected hose begins to spill out and reconnect. ( A friend has ls1edit (infinite license) so I can get him to change th fans)
. While I filled the car up (The new prestone all car all color 50/50 coolant) ran the engine , with the throttle body water hose disconnected, and filled up until I couldn't no more and the water began coming out of the Throttle body hose.
) where the needle slowly goes up to 210, and will stay put there from then on, no matter what the real temperature is...well my cars temp gage doesn't get up to 210* anymore, it actually stays noticeable below it
so why would an idiot gauge show a markedly lower temp?
