I'd like to replace the flywheel, clutch, pilot bearing and release bearing in my 94 Z with the SLP lightweight goodies. Where is the best place to get them??
WTB SLP clutch for 94 Z
tabahrTags: None
Check with Mike at Stealth Performance, for the SLP parts.
www.stealthperf.com
Also you may want to consider the Star Spec clutch & light flywheel.
www.speclutches.com
Gordon
tabahr
SLP price for light flywheel and clutch is 704.90
SPEC price for stage 1 with light flywheel is 638.00
SPEC insludes an alignment tool. Does SLP?
Opinions?? Recomendations??
Thanks
tabahr
The SPEC flywheel I priced is Steel, what is the weight saving over stock with this unit? SPEC also offers an aluminum piece for $160.00 more. Does aluminum have the same lifespan and durability as the steel?
this info is for an LS1......
The complete aluminum flywheel & clutch assembly was 10 lbs lighter than the OE stuff.
The flywheel had more than a 10 lb difference, but the clutch was a little heavier than the OE......... total weight was the 10 lb lighter.
Gordon
tabahr
THX..
I sent an email to SPEC asking what the weight diff is between their billet steel unit and the OE. I'll post the reply here when I get it.
I have posted this before but I will again. SPEC rocks. I bought a stage 2 clutch and installed it. It was slipping going into 2nd when I was on it. They sent me a stage 3 just charged me the difference. The stage 3 grabbed AWESOME! I took it to the track and missed the 2-3 shift (back into first) with a full 100 HP of NOS running. Blew the clutch right through the bellhousing of the tranny - parts everywhere!
I called SPEC to see if they could help me out and sell me a new disk and rebuild the pressure plate. I told them exactly what happened. They rebuilt the pressure plate and sent me a new updated disk for FREE! The owner/manager told me on the phone that the clutch should have ripped my input shaft off, so they're going to replace it - no charge. Tell me thats not standing behind your product!
Buy a stage 3 SPEC clutch.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
tabahr
reply from SPEC
reply from SPEC:
The stage 1 retails for $399, and is several steps above the stock unit.
The billet steel is the same weight as the stock unit. Most billet steels
are much heavier than the stock unit (except the hp GM Perf unit which is
prone to warpage and cannot be resurfaced). Our lightweight is the the
aluminum, which is 12 lbs lighter than stock, resurfacable, rebuidable and
guaranteed not to warp.
Let us know if we can answer any other questions.
SPEC Customer Service
800-828-4379
tabahr
Does anyone know if I can use my stock flywheel after it is resurfaced with the SPEC stage 1?
Yes, but if its not burnt or scored, I would just emery cloth it real good. I try to avoid cutting flywheels where I can. But I run a stock flywheel and a stage 3 SPEC96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
tabahr
THANKS for that info!! you just saved me $239.. I was going to replace my stock flywheel with 51 k on it, but now that I see there is no weight savings with the billet steel and my stock one can be cleaned up and reused I think I'll save some $$.
The original oem GM clutch gave me 130,000 miles until the disc developed a crack between one of the springs and the spline bushing....the disc still had plenty of material left.
Then I did a cheapo LUK clutch from Pep Boys, it was so bad after 30,000 miles it was tough to get up a highway hill and keep up with traffic.
I went with the Center Force 75,000 miles ago, and its slipping now, and will be dead soon....I just want to make it until I redo the engine in about 5 to 10 thousand miles.
I'm in this for the long haul, I need a good long lasting clutch...which will do me the best?
Gordon, you mentioned drilling out a port on the clutch slave cylinder, any details on that?
ThanxThe Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
[i]
Thanx [/B]
yes.... I've written it up a few times & haven't saved it ....duhhhhh....
Oh... it's an orifice in the line itself.
I'll post it here later... I don't have time to write it out right now.
Gordon
