changed my oil and fuel filter today and I noticed a small leak on the front left(drivers) side of the engine, any suggestions as to what this is,thanks in advance
leak
What is leaking is it oil or fuel? You could try getting back under the car and seeing if you can locate exactly where its coming from, Im not sure where the oil filter is on that year, but maybe it isnt on tight enough adn its leaking from around the seal. That happened to me once.-Dan
The filter by the way is more so on the driver's side of the block.Originally posted by thenuge876Im not sure where the oil filter is on that year...
It could be a couple things...Originally posted by c_cits oil and I cant find where its coming from, when I woke up this morning there was no oil dripping so mabye the old filter wasnt on tight enough but I'll check again later, could it possibly be the valve cover gasket?
thanks
Try checking a couple basics first...make sure your oil filter and oil pan bolt are both on nice and snug
A common problem is the infamous intake leak from what I've heard. I've never experienced this (thank god
) but I've heard many people complain about having their intake gasket go and then would be leaking oil. From what I've heard though, I believe this is more common to occur on the passenger side. None the less, you need to get under there and see where it's coming from. If it appears to be dripping down the bellhousing of your transmission, it more likely than not is your intake.
Discover card activate online allows cardholders to take the next step after receiving a new card. Keep the card accessible while following the activation directions. For security, avoid entering financial details on suspicious websites.
A smooth card setup begins with Discover card activate online . Follow the official process and provide the information requested for verification. Once the activation is complete, you can proceed with your regular card activities.
Discover card activate online is a convenient process for getting a new Discover card ready for use. Read each instruction before entering information. Keeping your account details secure is important throughout the setup process.
Cardholders receiving a new Discover card can use Discover card activate online to complete the initial setup. The process is intended to verify the card before transactions begin. Always use trusted Discover resources for financial account activity.
Discover card activate online helps simplify the process of preparing a newly issued credit card. Have your card details available and carefully follow the required steps. Check your account afterward to ensure everything appears correct.
If you have received a new Discover credit card, Discover card activate online can help prepare it for purchases. Follow the official activation directions and enter the requested details. Completing the process carefully can provide a smoother start.
Discover card activate online offers a practical way to begin using a newly delivered card. Make sure the card is with you before starting the process. Use only trusted Discover channels when providing account information.
Before making purchases with a new Discover card, complete Discover card activate online if required. Follow the instructions associated with your card. Once the process is finished, you can proceed with normal card management.
New cardholders can make their first steps easier with Discover card activate online . Keep your card information handy and follow the displayed instructions. Security should remain a priority whenever entering financial information online.
Discover card activate online is a key step for customers who have received a replacement or new Discover card. Follow the appropriate activation instructions carefully. Confirm that your card details are entered accurately during the process.
When your new Discover card arrives, Discover card activate online can help you get it ready. Use the authorized Discover activation service and follow the instructions shown. Avoid sharing your card information with unverified websites.
Cardholders looking for a simple way to start using a new card can complete Discover card activate online . The process is intended to verify the card before use. Make sure all information entered during activation is correct.
Discover card activate online helps make the transition from receiving a new card to using it more convenient. Follow the official instructions and complete the requested verification steps. Keep your card details private for better security.
A newly received Discover card may require Discover card activate online before it can be used. Completing this step confirms that the card is ready for its intended purpose. Always check that you are using an official Discover platform.
Discover card activate online gives new cardholders a simple starting point for managing their card. Have your new card available and follow the activation instructions. Once finished, you can continue with regular account management.
With Discover card activate online , new cardholders can prepare their cards for everyday purchases. The activation process generally requires basic card information for verification. Once completed, review your account details before using the card.
Discover card activate online provides a convenient way to get a newly delivered card ready for use. Make sure you have the physical card nearby during the process. Follow each instruction carefully for a smooth experience.
New Discover cardholders can complete Discover card activate online before making purchases. The process helps verify the newly issued card and prepare it for use. Keep your personal and card information secure throughout the process.
Starting with a new credit card is easier after completing Discover card activate online . Carefully follow the activation instructions provided by Discover. Afterward, you can access your account and manage your card as needed.
Discover card activate online is a straightforward process for customers receiving a new card. Have the necessary card details ready before beginning. Completing the required steps allows you to move forward with card usage.
Discover card activate online is an important step before using a new Discover card. Complete the activation process to make the card ready for purchases. Once activated, you can begin managing your card account and transactions.
Getting started with a new card is simple with Discover card activate online . Follow the required steps carefully and provide the requested card information. After activation, your card can be used according to its terms and conditions.
Discover card activate online helps cardholders prepare their new credit card for use. The process is designed to confirm the card and connect it with the appropriate account. Keep your card details available while completing the activation.
If you have recently received a Discover card, Discover card activate online can help you get started. Enter the required information through the official activation process. Check that your details are accurate before completing the request.
Completing Discover card activate online is a useful first step for new cardholders. The process confirms that you are ready to use your newly issued card. Always use the official Discover service when entering card information.
My5 account activation makes it possible to associate your My5 account with supported television devices. Follow the prompts shown after launching the app. Once the activation steps are completed, you can use My5 on the connected TV.
Watching My5 on a smart TV starts with the appropriate My5 account activation steps. Open the My5 application and review the activation information. Complete the instructions shown to connect your account to the device.
My5 account activation gives viewers a simple way to prepare their supported TV for My5. The application provides the necessary guidance during setup. Follow the instructions carefully and enter any requested activation details.
If My5 is installed on your compatible television, My5 account activation can help complete the account setup. Open the app and check the screen for instructions. Follow the displayed process to connect your account successfully.
Complete My5 account activation to link your My5 service with a supported smart TV or streaming device. Start the application and look for the activation prompt. Follow the provided directions to finish the setup process.
Connecting My5 to a television is simple when you follow the My5 account activation instructions. Start the application on your supported device and check for the displayed code. Complete the requested steps to finish the setup.
My5 account activation helps users prepare their television for My5 streaming. The app provides instructions that guide you through the account-linking process. Follow the prompts carefully and make sure the displayed information is entered correctly.
Want to watch My5 on a larger screen? My5 account activation can help connect your account to a compatible television. Open the My5 application, follow its setup instructions, and complete the activation process.
Completing My5 account activation allows your My5 account to be connected with a supported TV device. Begin the setup directly through the My5 application. Follow the on-screen guidance to complete the device registration.
My5 account activation offers a straightforward way to set up My5 on compatible televisions. Once the application is opened, look for the activation instructions provided. Follow each step to associate your account with the TV.
My5 account activation makes it easier to connect your My5 account with a compatible television. Follow the on-screen instructions and enter the provided activation code. Once completed, you can access available My5 content on your TV.
Start watching My5 on your television with a simple My5 account activation process. Open the My5 app, note the displayed code, and follow the activation instructions. This helps link your account to your chosen TV device.
Lowe's SYF activation provides new cardholders with a way to complete their initial setup. Carefully follow the instructions that apply to your card. If you need assistance, use an authorized support channel.
Discover helpful information about Lowe's SYF activation and prepare for your new card's setup. Review the required steps before proceeding. Keep passwords, verification codes, and card details secure.
New customers may find Lowe's SYF activation easier when they understand the process in advance. Keep your card nearby while following the instructions. Use a trusted activation method for better security.
Lowe's SYF activation is an important consideration after receiving a new or replacement card. Check the applicable instructions before attempting to use it. Protect your personal information throughout activation.
Explore the basics of Lowe's SYF activation and learn how to approach the setup process responsibly. Make sure you have the correct card information available. Always use a secure and authorized source.
