I have heard rumors that double clutchin can do alot of damage to your car, anyone heard the rumors of how it does or know how it could?
Double Clutchin
I would think it could do damage if you don't know how to drive properly...but double clutching isn't necessary any more...that is unless your racing in the fast and the furiousOriginally posted by JeaniusI have heard rumors that double clutchin can do alot of damage to your car, anyone heard the rumors of how it does or know how it could?
A friend told me thats the quickest way to get off the line, when you first feel it catchin first gear, floor it and pop the clutch, i havent tried it though
What you described is not true double clutching anyway. Some of the old timers can probably explain it better, but double clutching is used in trannies without syncros, I believe. Used to be every tranny. You push the clutch in, shift to neutral, let clutch out, match your revs to what you expect to be in the next gear, push clutch in again and then shift into next desired gear. Large heavy duty trannies like in tractor trailers still use this to some extent today. Of course, passenger cars don't because you have synchros that will take care of differing engine/tranny speed on it's own.Dave M
Bingo. That is the proper definition of double clutching. It is NOT a performance method of shifting. It is the correct method of driving older trucks, mostly 18 wheelers and such.Originally posted by Dave MWhat you described is not true double clutching anyway. Some of the old timers can probably explain it better, but double clutching is used in trannies without syncros, I believe. Used to be every tranny. You push the clutch in, shift to neutral, let clutch out, match your revs to what you expect to be in the next gear, push clutch in again and then shift into next desired gear. Large heavy duty trannies like in tractor trailers still use this to some extent today. Of course, passenger cars don't because you have synchros that will take care of differing engine/tranny speed on it's own.Tracy
Yep, you might need it to keep from grinding the gears on a rig, but you should know better than to listen to Vin Deisel and the fast & furious.
"You were granny shifting and not double-clutching like you should of! You never had me! It don't matter if you win by an inch or a mile!"
OK Vin, you dope.
Just watch out cuz if you don't double clutch fast enough, your glovebox may spit out washers and cause your floorboard to fall off... you can't have that... especially not when you're racing for respect.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
Speaking as a certified "old timer".......
I learned how to drive in a 1941 Ford pickup truck, with a 3-on-the-floor non-synchro gearbox. It worked exactly like Dave M described, and was used mainly for down shifting. I also drove a mid-50's English Ford (Consul???) with (if I recall correctly) a non-synchro box. That's the last car I can remember that didn't have a full synchro manual tranny.Fred
Hey third gen t5s have no syncro for reverse. Cant say as I have ever needed to double clutch in revese though.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
man are you guys crazy? double-clutchin is the only way to drive... ya'll are granny shiftin, not double clutchin like ya should (OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOHHHHHHHHH!!!)
