Hey Guys ..
Just heading home after work ... then I noticed the check guage light is one ... scanned and found that the engine temp guage is right at the red. I quickly pull over and shut the car down. I pop the hood and noticed that the overflow cap is off and fluid is at the top bubbling over. I look back and there is a trail of fluid down the freeway. So I let her cool down and limp my way to a point. Check the fluid strip and it is dry. I have my wife bring me some dex-cool and water fill her up and limp back home. I made it home and after a few hours of letting her cool down completly I went out to see what was up. Popped the radiator cap and it was way low. So cracked the top bleed screw and started to fill her up. Nothing was coming out of the bleed screw. The water level in the radiator was at the top. I turned the car on and still nothing coming out the bleed screw. The only thing happening is the temp guage is rising so I shut her down and here I am.
I replaced the water pump about a year or two ago along with the thermostat.
What could it be???? Blockage in the radiator???
Any help would be appreciated
for temp to build and to see/hear the gurgling of the fluids as it starts swooshing around. Funny thing not being stuck on the side of the freeway ..its amazing what you CAN hear. Well I stuck my ear around and I hear this whining sound from what looks like the thermostat/water pump area. Now I am not trying to wish the ball in the cup but I am figuring either some is preventing fluid from getting to the pump or the pump is F'd up and sending the fluid around the loop.
. Pumps are only about $89 at your local Napa so if that is your culprit it isn't a big kick in the wallet as say a radiator.
