just recieved sway bar front and rear. any tricks to install this ?
sway bar
sway bar
2001 Trans Am WS6 M6
Tags: None
its pretty simple and straight forward. Just follow the directions and get a second set of hands to make it go a little faster.97 TA, M6, JBA ceramic coated headers, Borla Cat-back exhaust, 1.6 RR, 160 Thermo, LT4 knock sensor, CAI, Bils, Hotchkis all around, GT rotors, B&M shifter, Magnecor wires, Granatelli MAF
In the shop LT4 Intake and heads.
No, any chimp can do it. Just make sure to use the special silicone grease on the poly mounts and tighten the end links enough to smash the poly end link bushings until they bulge out a little bit. Make sure it's centered as well and pay attention to the direction they tell you to put the split bushings.
Does it come with new bolts and tube spacers? If not you may need a set as usually the originals will just break right off. You can get them at Autozone. Just measure the tube spacer and match up with what they have.
i installed sway bar then i took for test drive but when its comes to corner and i punch just a little bit rear like too weak or its feel to weak i don't know how to describe it. any one know what wrong or my panhar bar can handle it now? i want to change panhar and control arm in future and also i need shock and spring too.2001 Trans Am WS6 M6
Stock pan rod should handle it.....the car should bite(turn) hard when you turn the wheel. Body roll should be minimal. The rear should track with the front and stay flat through the corners.
What SB did you go with??John
97RS "Arrest me red" - LETSCEM - under the knife
02WS.6/TA #4024 "Wash me again black" RDOZREL - Hotchkis STB, MTI lid, BMR SFC's, BMR SB's, SB Brake Lines, SureStop rotors, Carbotech pads.
99 Bravada
