Hey guys ...
As you may know I had a problem a few weeks ago where the temp guage hit the red. I quickly shut her down and limped her home (a few miles). Well when I got her home I heard this whining sound coming from the water pump. Over the weekend I replaced the thermo, water pump and radiator.
so here is where I get stuck or lost ..
First off can someone confirm if where the hose from fill can connects to the radiator? There are two openings at/near the radiator cap and I need to make sure the orientation is correct.
What is prompting that question and giving me a funny feeling something else is wrong is that I have reversed the two hoses (first on top then on bottom) and the fill can in both cases ends up with water coming out the top. Now I have only drained out the fluids from the radiator NOT the block to completely remove ALL the fluid however so far I have dumped about 5 gallons of water and two things seem to be happening. Water backs out of the fill can and the radiator seems to suck up water pretty fast. Its like it is evaporating or going someplace else. The temp guage never crosses the 185 mark and when it reaches that level the fans come on. I don' want to say it because I don't know but could something else be wrong that is more major than I think???
I hope I explained it well .... I can clarify if you need me to.
thanks ....
thanks ....
