OK, on my actual seatbelt buckles (attahced to lower console below armrest) the buttons, which used to be red, have scratched and faded to a pink shade. I decided I wanted to remove them, tape the buttons off, and re-spray them a fresh red. One problem....how do I remove them? Would I have to remove the console?
Picky Little Details
yup...Originally posted by Mark BPassenger & Driver Seat have to come out. Then there is a torx bolt that bolts the seat belt to the floorplan. I forget what size it is.
the casing is removable too...just have to pry it off. Once it's off, you can spray, let dry and replace the casing with some adhesives. I know cause my back seat casing fell off once...LOL and I had to glue it back in place.
I didn't take my seats out. I got mine out by sliding the seat all the way forward, removing the bolt and pulling the belt out from between the seat and the console. The bolt is a T50 (31 lbft when you put it back).Originally posted by Mark BPassenger & Driver Seat have to come out. Then there is a torx bolt that bolts the seat belt to the floorplan. I forget what size it is.
Bruce, μολων λαβέ
Only 1984 up to 1990 model years are affected by the seat belt recall...He's got a 1992...Originally posted by DisiferI thought I read somewhere that there was a recall on seatbelts. An easy way to tell if your's needed the belts replaced was if the buttons faded really fast or something
Bruce, μολων λαβέ
