ok im sure i need to do my opti... 120,000 miles... its time... but i was wondering.. do i have to by a new opti... or can i get that new MSD cap and rotor kit....I mean doesnt the opti go bad because the points wear thin inside the stock cap? any suggestions?
opti Question?
It's a combination of the normal erosion of the electrodes of the rotor & cap & possible corrosion in the optical encoder section (94 models) & possibly the connector up top & possible wear of the plain bearings that the whole thing turns in including the encoder. In an otherwise good running opti, a cap & rotor kit may do the job, but there is a possibility of seeing symptoms of the other problems while you're in there, then you may decide you need a new opti or risk having to redo it again later. You probably won't know until you take it apart.
at 120K, I would just replace the entire thing. If mine lasts that long I will be very happy! Kevin is right of course, you could decide to just replace the cap and rotor... but... then you could easily be taking it all apart again in a few thousand miles to do it all again. IMO, it's not woth the savings if it doesn't provide peace of mind.Tracy
Originally posted by 94T/A GTcan i get that new MSD cap and rotor kit....?
As mentioned, one of the other weak points in the Opti is the bearing. Mine was almost impossible to turn at 50K miles. Replacing just the cap and rotor will leave you with the possibility of a worn out bearing. And, the optical sensor in mine was filled with rust particles, blinding the optical system. But the cap and rotor was just like new.
Are you aware of the discount prices available from Jason Cromer/Sam Tayler and Dal Slabaugh/VanDevere Olds? Still an expensive piece, but only about 1/2 of what the dealer would charge you for the new part.Fred
You can get a new opti for around 300-350 US. This is one of the parts that is better to buy new and shop around for. The local dealership here wanted to charge 1200 Cnd for it
Just a note you should also replace the waterpump while your in there if you haven't recently, a bit more cost but it should be done because if it brakes it can take out the new opti and with that many miles on your car...94 Formula Firebird, 355, heads port and polished, cc503 cam, 30# injectors, PCMforless Tune, B&M 2400 stall, K&N CAI, BBK Sorty Headers, Magnaflow Highflow Cat, Borla Catback exhaust with electronic cutout.
