Ok so i replaced the 02's and got the extensions, in the process i noticed the harness on the passangers side got melted by my header slightly. Can i just splice into it, and extend it long enough to keep it away from the heat??
Melted harness??
Yes, you can repair the engine harness.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Originally posted by 95z28thanks, i thought so but i just wanted to double check since it is the piece with the 02 sensors on it.
The sensors extract reference air from the wiring (like a straw). If the wiring is modified, you run the chance of screwing up the operation of the sensor.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
