Interesting.... I did that with the 3-element tail lights on my 1966 GTO about a year after I bought it new.... It was cool, 'cause most of the tail light lens was under the louvers....
Bill - Was the job tough? I know it says most cars are about an hour, and only need a few tools. How long do our cars take approx? Thanks.
It was a breeze. Probably took 1 hour. Tools needed :
Wire strippers, dremel (to cut the outermost light fixture hole a little bit bigger ... so you can fit a dual filament socket & bulb in it), electrical tape, wire ties.
Directions are really good, and the wiring is a breeze. The kit comes with all the parts you need. Currently the outermost light of the trans am taillights are a "driving light" only. This needs to be modified to function as a brake light and turn signal as well. Thus a larger socket replaces the smaller stock one. That is the hardest part of the mod... just make a template of one of the inner two socket holes, and use a dremel to cut the outermost socket hole to be the same size. Goto autozone and by 2 new sockets & 2 bulbs (5 bucks total) and you are good to go! If anyone needs any help at all, PM me! I'd be glad to help!
1997 Trans Am WS6 Black M6
370 RWHP / 352 TQ
CC306 & Comp behives, LT1 Extreme Duty timing set, 1.6 RR's, CSR Elec Water Pump, Pacesetter LT's & ORY, GMMG w/ Ovals, K&N, Air Foil, TB Bypass, !AIR, !EGR, !CAGS, 160 deg thermo, LT4 KM, PCM tuning by Total-ReCal, March Pullies, Pro 5.0, 4.11 gears, LS1 alum DS, BMR strut tower brace, UMI SFC's, LCA's w/relo brackets & panhard
