a 1994 Camaro VG 3.4L engine, where is it located under the hood?
Where is the MAF located in this vehicle?
Follow the air intake plumbing, you'll see it...it sticks out like a sore thumb. It'll be a thick piece of metal along several feet of rubber.Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Hmmmm...from the looks of that drawing and some quick looking around on the internet, I don't think the 3.4 had an MAF. What leads you to believe it does?Steve
Mods
Mods
Mods
Not a problem. Let me take a look through my Chilton's when I get home and I'll get back to you for sure.Steve
Mods
Mods
Mods
the MAF is easy to find. its the only thing between your throttle body and air filter thats inline with the whole tube setup with a plug in wire connnection to it.....
wolfmans leary of this thread...........ftr
I thought the 3.4 was MAP not MAF?
edit:Check the photos, if you don't have something that looks like #12, then you should have something like #10.
http://shbox.com/1/component_location_views.html
these are 8 cyl photos but the general locations and appearance are the same.
Bruce, μολων λαβέ
The 3.4L wiring diagram does not show an MAF sensor, and Chiltons does not show an R&R procedure for an MAF sensor on the 3.4L. I think is was added to the 3.8L V6. On the 3.8's its mounted to the front of the throttle body.Fred
