is there a spray cleaner you can use to clean the MAF sensors, such as carb cleaner????
Spray cleaner for MAF ?????
Kevin Villier 2002 SS #186 - 6M with Hurst and "short-stick", T-Tops, navy blue, chrome SS wheels, Bilstein suspension, SS grill, BMR STB, chrome-moly panhard rod and LCA's, SLP SFC's, PPC LT's w/ RT hi-flo cats and hi-flo Y, TEA Stage 1.5 5.3L heads, TR224 cam, ASP pulley, SLP loudmouth, Direct-Flo lid, Holley Power-Shot filter, Mallory polished MAF ends, 4.10 gears.
Louisville, KY
SSOA F02-0186
KY F-Bodies UnlimitedTags: None
Electrical cleaner is safe.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Yea, some say that you shouldn't clean it with any cleaner, but I'm with Rob. I used electrical contact cleaner and it helped quite a bit. The sensors were actually black from all the build-up over the years. After it was cleaned, the idle changed (for the good) and ran much smoother. Just be careful when you clean it.94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
I wouldn't touch it at all. I'm with Rob and Craig, electrical cleaner (which is, essentially, rubbing alcohol).Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
I have also used a q-tip and alcohol. Just be nice with it.
