Anyone know the gm part number for the 1LE driveshaft for a lt1 f-body?
Part number
Part number
1995 LT1 bird
2005 Dode SRT-4
6 dics cd changer, 10 inch MTX fully loaded with moonroof and viper style seatsTags: None
10085375
thank you very much1995 LT1 bird
2005 Dode SRT-4
i have an automatic will this fit, and is it prebalanced? Will i notice any sort of performance gain or feel with this?1995 LT1 bird
2005 Dode SRT-4
Yes it will fit. You probably won't notice it, but an aluminum DS will put slightly more power to the wheels due to a slighlty less drivetrain % loss. The only thing you may actually notice is less of a vibration on the highway if you happened to have one before.Originally posted by DetroitLT1i have an automatic will this fit, and is it prebalanced? Will i notice any sort of performance gain or feel with this?black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
www.ws6.com shows a 1 hp and 5 tq gain at the rear wheels with the 1le driveshaft.Dave M
