Hey guys i just noticed that my water temp is not coming up at all it stays all the way below 100. I have a 98 z28 so you know. What could this be.
H20 Temp doesn't come up??
The above info is for an LT1. The person who asked the question has an LS1. Are you sure the coolant gauge temp sensor is in the same location on an LS1?Fred
The temp sensor is a $15 part. It shuoldn't take more than a few minutes to replace. Find out where it is, check the harness wire to make sure it didn't fall off. If the wire is still intact, you can test the temp sensor with an ohm meter. I can give the table of resistance vs. temperature, if you want.
Hard to believe there are no LS1 owners here who can help you out.Fred
