Thanks Kev. Very interesting points you mentioned.
Regarding Cell 18 at idle, I haven't seen it being used when at 0 mph, however, I see it used a lot at 0% throttle (.55 TPS volts in my readings), and RPM is >= 575 where desired idle = 550. Interesting that it isn't supposed to be used at 0% throttle.
Regarding the IAC, I'm always questioning the condition of mine. Although the readings have always appeared to be correct (could have sworn Fred said 20-40 at idle), it's definitely not close to 40-50.
The reason why I question the IAC, though, is...I had a problem that started a few years ago. Every I started the car within 4 hours of previously driving it, the idle would shoot up to 1500+ RPM for several seconds. After several seconds, it would slowly decrease to normal idle. I hate this because just as the oil pressure is building, it's as if I'm revving the motor. I thought it had something to do with the IAT sensor resting right on the coolant line. So I relocated it to the CAI, and the problem went away. As of last month, however, it's back and as bad as before. So I'm thinking, maybe it's the IAC? Why else would the startup idle shoot up to 1500+ (up to 1800 at times) for several seconds when the motor was warm?
I did try adjusting the stopper screw on the TB to decrease the split in idle BLMs. However, I had no such luck. I ended up getting the TPS volts to .76, and the BLMs around 128/109 in cell 16, but the split didn't decrease. So I figured I'd stop playing around with it. And anyway, the BLMs are split across every cell (ranging from 5-19 difference) except in cell 9 - where they're 128/128.
Regarding the rocker arms, I re-adjusted all on the driver's side a few months ago. Originally, both sides were at 1/2 turn past 0 lash. I ended up re-doing the driver's side to 3/8 turn past 0 lash, and no difference.
Wow, thanks again Kev, you got me thinking on a few other potential problems.
But anyways, they're going in to Napa tomorrow to get sanded down. Will this start to chip the ceramic coaing?
j/k
LOL
