Originally posted by 1sickbird
needed help real bad part 2
Well it's brake fluid so if it's dot 3 or 4 it's going to be a dark purple.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
hydraulic clutch system .hydraulic clutch fluid GM part no 12345347 or DOT-3 brake fluid. i got that from manual book. could you tell me how to bleed it please2001 Trans Am WS6 M6
I can't because I don't have a bleed-able system.Originally posted by 1sickbirdhydraulic clutch system .hydraulic clutch fluid GM part no 12345347 or DOT-3 brake fluid. i got that from manual book. could you tell me how to bleed it please
I bet it's a 2 person job where 1 person pushes down the pedal while the other under the car opens the bleeder valve, lets it squirt, then closes its. Then the person inside lets up on the pedal and you do it over again. Keep rechecking the fluid level so you don't run it dry. Do it till you get the air out of the system just like brakes. But I'm not a gambling man.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
The bleeder valve on the LS1 clutch slave cylinder is very difficult to get to. Given what I've read so far, you may not have the knowledge to do a correct bleed procedure. Might be best to find a shop with some experience specifically with the LS1 clutch. The dealers see very few of these cars for service, so they generally don't know much about them.Fred
So, did you put hydraulic(clutch reservoir) fluid into the actual transmission? Like Jeff asked, is your clutch fluid reservoir full? Did you put transmission fluid in the clutch reservoir?Originally posted by 1sickbirdi changed the transmision fluid because i didn't know that clucth fluid is different with transmision and now i don't know how to change clucth fluid and i hope my clucth is ok.
i filled both place with dot 3 fluid like on caps says. and its lot better i can easily donw shift and everything. and thank you for you guys helped i couldn't do it without you guys help.and that saved me $1100 at pontiac dealer.2001 Trans Am WS6 M6
Good. Will you believe me the first time next time? (joking)Originally posted by 1sickbirdi filled both place with dot 3 fluid like on caps says. and its lot better i can easily donw shift and everything. and thank you for you guys helped i couldn't do it without you guys help.and that saved me $1100 at pontiac dealer.
lol i believed you since the beginning bro but i didn't know that trans fluid is different with clutch fluid. but anyway thank you for helping me from the start bro.now i'm confused between SLP Shocks/Springs, Front/Rear, 93-02 Bilstein/Eibach (set) or PaceSetter Exhaust Ceramic-Coated Long Tube Headers, 2000-2002 LS1 F-Body with Emissions Fittings, With TSP 3" Y-Pipe with Hi-Flow Catalytic Converters - On Special!
Price: $700.00
just add little , now you scaring me jay what will happened?2001 Trans Am WS6 M6
Hopefully the clutch will work now. If it's working, everything is fine.Originally posted by 1sickbirdjust add little , now you scaring me jay what will happened?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
works just fine now bro thank you2001 Trans Am WS6 M6
Then don't worry about it.Originally posted by 1sickbirdworks just fine now bro thank you2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
