OK, on a panel like the front bumper or rear berger (the plastic like stuff) should I wet sand or dry sand? I have 1000 and 2000 grit paper, should I start with 1000 then go to 2000?
Sanding question
What are you trying to accomplish? (Why are you wanting to sand paint?)Originally posted by 99v6camOK, on a panel like the front bumper or rear berger (the plastic like stuff) should I wet sand or dry sand? I have 1000 and 2000 grit paper, should I start with 1000 then go to 2000?
Any finish sand should be with water to prevent the sandpaper from loading up and going the paint.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Oh yes. Wet sand with 1000 grit before any coats go on.Originally posted by 99v6camI'm making a black berger. I ended up starting with 600 (wet) then put the primer coats on. Looks good so far, I'm debating whether or not to sand the primer before the black coats.
Are you using enamel or lacquer?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I agree with Jeff. Absolutely sand the primer. If you burn through the primer in any spots after sanding, re-prime those areas and wetsand them again. This will give you a nice, even surface. Good luck.Originally posted by 99v6camI'm making a black berger. I ended up starting with 600 (wet) then put the primer coats on. Looks good so far, I'm debating whether or not to sand the primer before the black coats.SOLD: 2002 Trans Am WS.6 - Black on Black - 6 Speed
