Alright...
I just recently added some bolt ons and now I am experiencing some problems. First I guess I need to give you a list of bolt ons so here it is:
BBK Headers, BBK 58mm Throttle Body, BBK Power Pullies, SLP Cold Air Intake, Ported and Polished Intake Manifold, MSD 8.5mm Plug Wires, and I also had new plugs put in but not sure what kind.
Now the problem...
I only drive the car 10 miles every 2 weeks. So, when I start it up it will run great at idle. I can drive it 2 miles down the road and it will still run great at all RPM ranges. When my engine starts to warm up it is steadily warms up until it almost overheats and then my fans kick in. This is due to a fan problem I had earlier and both of my fans are wired together so they kick on just before it overheats. So once the fans kick on it will cool off very quickly. The fans kick off again and it begins to overheat again. This time it starts to bog down like it is running way too lean and my RPMs will bounce around while idleing. At this point I shut the car off and I have to wait for it to cool down and then I can start it up again and it will run fine.
I'm guessing it has something to due with not getting enough fuel when it is hot...but I'm not the mechanic and that is why I come to you all. Any solutions...?
Thanks again everyone!
Edit: Don't forget it's a 93 so it has speed controlled A/F Ratio
Now the problem...
, so I need to find a way to fix that.
