At 500 flywheel HP, the 36's will be close to 80% duty cycle, which is where you want to be. 42# is as large as you an go on a stock PCM, because that is the largest high impedance injector you can get. To run larger, low impedance injector on the stock PCM, you need a "black box" converter.
An alternative to larger injectors is higher fuel pressure. The pintle style injectors are comfortable at 58psi. That gets you 15% extra flow out of an injector that has been flow rated at 43.5 psi.
The larger the injector, the harder it is to get it to flow the low fuel rates required for idle. Its hard to turn an injector down below a 1 milli-second pulse width, it that's what it takes to idle. That's why you need to go to a low impedance injector when the size goes over 42#. The low impedance injectors are much faster, particularly when combined with a high resolution, high quality driver in the ECU.
And, like Kevin pointed out, it will require alittle additional tranny setup within the PCM. I would also suggest adding at least Corvette if not Billet servo's depending on whether or not this car is your dailiy driver.
