Throttle Bodies
  • Throttle Bodies
    I wondered what you guys thought would be a good throttle body for a 396? There seem to be quite a few out there. Is the twin 58mm that I have seen the best size I can get?
    Is bigger better in this case?
    13.685@102.11
    I would honestly think that a 58mm TB would work well for your application.
    There are others that are smarter than me also...so I'd wait for their opinions as well.
      A 58 would be the biggest you could go, but I don't know if it would be the best. I think a 52 mm would suffice for a 396 unless you were going with forced induction, but I'm no expert. I know even the stock 48 mm is more than up to the task of a well-modified 350.
      Dave M
        Fred says it all in another thread:
        Just a reference point or two.... my 381ci stroker, turning in excess of 7,000rpm and making 500HP was only using 77% of the flow capacity of the 58mm Holley throttle body. That is confirmed with engine dyno testing. GM puts the same 48mm TB as the LT1 on their RamJet 502ci/502HP crate engine.
        EDIT:
        Oops, sorry Fred...didn't mean to steal your post.
          The 52mm TB will flow enough air to make 500 flywheelHP. We verified that on the engine dyno with my setup. Even though I have the Holley 58mm TB, the air flow reached maximum at 77% blade opening, and opening the blades farther did not increase air flow.
          There is also a 54mm TB made by AS&M that can be considered.
          There is no downside to using a 58mm TB on a high HP 396.
            So would it hurt, lets say a stock car, to put on a 58mm throttle body? i dont think it would but doesnt hurt to ask. And also would there be any power gains there? I dont think there would be any but thought i'd ask that too
            96 Camaro Z28, T-tops, 6 Speed, Slp CIA, Flowmaster cat-back, 3:42 gears
              From what I've heard, an oversize TB would actually hurt performance on a stock LT1.
              So, in turn, there obviously wouln't be any performance gains.
                I am guessing than that I should perhaps leave the stock throttle body there unless I can pick up a cheap replacement?
                500hp is what I am shooting for.
                13.685@102.11
                  I'd say that a 52mm TB would work just fine...but using a 58mm TB also would work fine and wouldn't hurt performance. You would only be using 77% of its potential.
                    Ok. I'll look for a 52mm or a great deal on a 58mm.
                    I guess I should ask: Does the same ring true for the MAF? Is bigger not better in this case too.
                    I'm just trying to figure out all of these other things I need to add. I know that the injectors for one need to change and I believe the fuel pump as well, but what do you guys think about the MAF? Do I need a bigger/better one?
                    13.685@102.11
                      Larger injectors and a larger fuel pump are a must in a stroker build. I'm not positive, but proabaly 48 lb./hr. injectors would be good, and I'm not positive on the fuel pump. Once again, wait for Injuneer or someone who has experience on strokers to more thoroughly answer your question...all I can tell you is that you will need them.
                      As for the MAF, I've heard from many that keeping the stock MAF is the way to go. I have a good idea where to find some information. Gimme a second to find it really quick, and I'll post in a minute or two.
                        This is usually a good site to check out when wanting to know what things go into a stroker build.
                        Granted this is set up for nitrous, and I believe you wanted to be all motor, but there are a lot of good things for reference here
                        http://members.aol.com/InjuneerZZ/Mod.htm
                          I have heard before that 36# injectors were good to 500hp, I am not sure if that is right though. I read that on cz28.com
                          I am going to buy a set from Thunder Racing that are 42# to be safe. If I can keep the stock MAF that will save me some dough.
                          13.685@102.11
                            I wasn't sure on the 36...I did type in 48 but I actually meant 42. I've heard that 42lb./hr. are good for the amount of hp that you are looking at.
                            I'm sure when Injuneer takes a look, he'll be able to give you all the info you'll ever need
                              He's gonna have to start charging us as a "consultant"
                              13.685@102.11
