My left headlight on my 99 goes down and the motor still runs and sounds like the gears stripping. They still go up and down, but it wont shut off. I had to pull the two 15A motor fuses with them up until I know what to do....can anyone help? Do I need a new motor? Thanks, jessica
Headlight motor question
mine did that only it would stop and then every time i hit a bump it went down a lil. my problem was that the gear had some how broke away from the shaft and it would barely rasie it. but i think ur motor might have a short in it2009 Honda Civic EX- the daily beater
You need a new gear for the headlight motor...Options:
1) Rotate 160º the damaged nylon gear
2) Purchase a new nylon gear like stock.....
3) Purchase a brass gear.. ore solid
Anyway, Here is the full info you need:
http://www.bfranker.badz28.com/headlightfix/index.htm
Regards
Dochidalgo97 A4 Pontiac Firebird Trans am with $everal mod$
