Well wednesday night the best run I made was a 14.7. Seems kinda high, I am an average driver, but i'm definatly not bad. I think its my clutch. But not for sure. What else could it be? And what do some of you guys run with near the same mods as me or a little less or more.
This weeks track times ??
Post all of your stats for a better answer.Originally posted by 96CamaroWell wednesday night the best run I made was a 14.7. Seems kinda high, I am an average driver, but i'm definatly not bad. I think its my clutch. But not for sure. What else could it be? And what do some of you guys run with near the same mods as me or a little less or more.
What was your 60' time?
1/8 mile?
1000'?
1/4 mile trap speed?
New tires? Bald?
What did you launch at?
Being a good driver definitely helps. I know many people who drive stick that could pull off better times simply based on their driving.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
Ok here is the other stuff....
Best 1/4 mile run
RT - .939
60 - 2.355
330 - 6.348
1/8 - 9.605
MPH - 73.78
1000 - 12.395
1/4 - 14.754
MPH - 95.25
Worst 1/4 mile run (spun through first)
RT - .608
60 - 2.475
330 - 7.444
1/8 - 10.884
MPH - 70.56
1000 - 13.770
1/4 - 16.181
MPH - 92.5696 Camaro Z28, T-tops, 6 Speed, Slp CIA, Flowmaster cat-back, 3:42 gears
The first thing that pops out at me is the 60' time. You could shave at least .2-.3 off that with some practice, and that could translate to half a second at the traps. Your mph seems a little low too, but I'm not the expert that some of the other guys here are. What was the altitude and weather like? What about track conditions? Did you cool the car down between runs?
You seem to have just a CAI and exhaust for mods, so I'd say low 14's would be normal under decent conditions, maybe even a high 13 with a good driver and good conditions, and you could almost get there just by working on your 60' time.Dave M
i know the big time drag racers say a race is won in the first 60 feet so that would be where i would work on. aka tires clutch rpm2000 trans am auto, Afr 205,tr 220/220 112, mti lid, 160t,umi sfc,hooker headers and ory y,loud mouth. bellow,pr's,harland rockers,new lifters,ls6 oilpump,rollermaster doubler roller, msd wires.
Your clutch and tires will also play a pivotal role in getting you out of the hole quickly, moreso than your air filter. I'm not saying not to clean your air filter (duh! lol
), but if your tires and clutch are worn, its time to replace them. Your face will go from
to
at the next run down the 1/4 lol
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Depens how handy you are with a wrenchOriginally posted by 96CamaroHmm, well i've never taken the transmission out of a car before. Isnt too hard is it?
I've never done it either, I had a trans. shop do the clutch. One thing to note...if it is the original clutch, you may want to consider doing the clutch master cylinder as well. Not sure if it was just because of the age of my car or not, but when I talked with SLP when I was considering their clutch, they said that regardless of what I go with replace the master cylinder. Apparently not replacing it can cause problems when you replace the clutch. Something you may want to look into...or someone else can chime in on.Originally posted by 96CamaroHmm, well i've never taken the transmission out of a car before. Isnt too hard is it?Steve
Mods
Mods
Mods
