Im going to order 3:73 gears.. Anyone know what carrier I have?
Ordering gears...
GU2 = 2.73
GU5 = 3.23Fred
Not to hijack the thread but i was wondering if someone could give me some info. I had 273 ration then i put in 3 series 373's, well i had them put in, and it rides ruff, and whines? Is there anything i can do?1995 LT1 bird
2005 Dode SRT-4
6 dics cd changer, 10 inch MTX fully loaded with moonroof and viper style seats
If the gears "whine" really loud, they were not installed correctly.... incorrect contact pattern or pinion depth. Of maybe if the whine is minimal, they are the Richmonds, that tend to make a bit more noise than the factory gears. Just how bad it the whine, and under what conditions does it whine?Originally posted by DetroitLT1Not to hijack the thread but i was wondering if someone could give me some info. I had 273 ration then i put in 3 series 373's, well i had them put in, and it rides ruff, and whines? Is there anything i can do?
No way simply changing the gears can produce a rough ride. And when changing the gears, there's no reason to touch any of the suspension components that might cause a rough ride. Exactly what do you mean by rough ride?Fred
