Ok, well here's the problem. On the highway whenever I turn right at all, there is a grinding type sound comming from the front. Doesn't do it when I turn left, just right. Think it might be a wheel bearing, but not for sure. Any input appreciated.
Grinding noise
The wheel bearing is a sealed hub/unit that also contains the abs sensor. In order to change it, pull the front wheel, remove the caliper and hang it out of the way (no need to breach the system), pull off the brake rotor. The hub assembly is held in place by 4 bolts, unclip the abs connector on the back side and remove the hub. Assembly is the reverse order. Plan on about $140 for a hub/bearing assembly.
I wouldn't worry too much, it's a real easy repair. It's actually easier than the old spindle/bearing setup from years past. No bearings to pack with grease, no mess...... 5 lug nuts, two brake caliper bolts, pull the rotor and harness connector and unbolt the 4 bolts. Really simple.Originally posted by 96CamaroI was afraid that I might have to change out that whole thing
. I'm pretty sure thats what is makeing the noise.
the only downside is the increased cost.
