Ive got a ZZ4 Crate engine w/ hot cam kit option. I live in CT and drive to Pittsburgh about twice a year. Its about an 8 hour drive at between 2500 and 3500 rpm. The motor typically runs great the whole drive. The only problem is that it eats about a quart of oil during the 8 hour trip. Does anyone else have a problem like this? Im 95% sure there is no oil leak and have never had a motor eat this much oil before. Also, the motor is relatively new, only about 10,000 miles. Any suggestions would be a great help.
zz4 sucking up oil
Well at least valve seals are easy to do.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
under what conditions do the valve seals typically leak? it doesnt seem to have the problem when trips are kept down to under an hour.1980 Camaro w/ ZZ4, most of the info is correct... www.pitt.edu/~hhh1
