ok guys, im gonna be doing the clutch in my car. that is if napa has it in stock or in by saturday. just wondering if u had any advice for me. thing that worries me is the torque arm. after tis up on jackstands, should i just put the jack under the pumpkin(rear end) to hold it? car is in sig
Need help wit clutch
whenever I do work on the rear of either of my cars I support the rear with stands under the frame rails and use a jack under the pumpkin. That way the car is stable and I only have to worry about the rear end moving by virtue of my using the jack.97 TA, M6, JBA ceramic coated headers, Borla Cat-back exhaust, 1.6 RR, 160 Thermo, LT4 knock sensor, CAI, Bils, Hotchkis all around, GT rotors, B&M shifter, Magnecor wires, Granatelli MAF
In the shop LT4 Intake and heads.
When I did my clutch I didn't pull the torque arm. I just unbolted it from the trans and let it sit upward. Didn't get in my way at all.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
im worried bout the springs. cuz on my 83 t/a when i resealed the rear end, i just unbolted the t/a and WHAM! the rear shot down and the springs were barely in there.but i think ill just use an extra jack to hold the rear2009 Honda Civic EX- the daily beater
Yes, use a jack under the rear end. If not there is nothing holding it to the car but the shocks.
When I did my clutch though I just put jack stands under the front, and two jack stands on the rear end. One on each side of the pig nose.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
