Does my 1985 Camaro 5.0 4 bbl have a govenor. Im guessing so and does anyone have a clue of what wire it is on my ecu? Thanks for the help!
camaro ecu
twisted85Tags: None
dude!! don't go cutting wires!! you must have a computer controlled quadrajet right? Don't mess with it. It all works in harmony. Governors are gonna be ECM programmed and set for speeds or a mechanical device for throttle position restrictions on the carb. If you wanna go faster get a chip or something. Don't cut any wires.
93 Z28: LT1, AT, 3.73, Insulated IATS, pcmforless.com custom computer program, CAI, BBK 52mm TB, 160 thermo...etc..
clik below on homepage for pics of my 93 Z28
twisted85
no i have a 4bbl 305, but i no that all cars run a computer to control eveything. Can i get a chip for a non fuel injected car? If not then cuttin wires is what im gonna have to do. Ill just wire it to a toggle so my check engin light wont stay on all the time
tabahr
Cutting wires will only hurt your performance. There is no "governor" like you are talking on your car. My car is a convertible, so it is speed limited to 110. Listen to the previous poster and leave the wires alone. You subscribed to this board to get expert facts.... Two people have told you now. Cutting wires will NOT make your or any other car run better or faster.
If you really have an undying need to eliminate the PCM, I recommend buying a non-computerized carb and go pull a non-computerized HEI off a 70's F-bod. Installation is simple.
The computerized stuff will absolutely NOT work properly without the PCM hooked up. A cousin of mine tried it. It turns the car into a gas sucking dog.
Wait a sec, before you reach for the wire cutters....
Just a little caution here.... The 'jet that is on your car is equipped with some computer controlled selonoids that will not react the way you think when disconnected. Specifically, the mixture control seloniod. It will default to rich-full, to protect against a lean condition due to a computer failure. In addition, the spark advance module and some others will take on a psuedo- limp home mode. The closest thing a carb car has to it. You will experience some strange driveability problems. The only way to avoid this completely, is to replace the carb, and the distributor with a pre-ecu model. This is for off-road only!!!!!!!!!! It is illegal to do this to a street driven registered auto. /disclaimerOriginally posted by twisted85
My .02 -- Research before you slice... HTH :-)
WickedLT1's Home on the Web - Wicked Pictures
95 - Trans Am - LT1 - 6Speed
Car Status: Hmm, winter projects coming up...
BowlingSS
Re: Wait a sec, before you reach for the wire cutters....
My 84 Camaro had a computer problem and it default to rich-full, to protect against a lean condition. It ran very bad and used a gallon every few miles.Originally posted by WICKED LT1
Bill
