First I'll explain my situation.... I have a '95 Saturn SC2, it's fairly quick considering it's very lightly modded, I love the car to death, BUT, it cannot handle being abused. However, even if I baby it, it still falls apart on me. I can no longer afford to fix the car, so it has to go. Now ! I love trans-ams, especially the LS1. They're beastly, fast, beautiful, etc etc. However, like Saturn, they are another GM product, so to the point: Are LS1's (and I suppose LT1's) reliable? What common problems do they seem to have? Does the car need to be maintained on a constant basis, and most importantly, can it handle being ran hard? If you guys could help me out, I'd really appreciate it!
New here, couple questions.
I don't know much about the LS1, but I can tell you that my LT1 gets abused by me and takes it very well. I have 80,000 miles on it with a lot of 1/4 mile runs and some autocrossing. I maintain it with regular oil and fluid changes and aside from the water pump leaking and taking out my opti a few years ago I didn't have any problems with it while it was stock. Oh yeah, I absolutely love the car. Hope that helps.
Andy'94 Formula M6, XE224/230 w/1.6 RR's, hardened pushrods, Comp R lifters, SLP ceramic coated shorties, Random Tech cat., Flowmaster cat-back, CSI water pump, vented opti, PCM tuning by Spraytheway, BMR k-member, SFC's, DSL, LCA's & brackets, adj. PHR
339 RWHP, 341 RWTQ
'00 S-10 ZR2
After working in the business, I realize, everything breaks. Some people say "imports are more reliable", "dont buy fords", "gms are no good". Its all nonsense. Everything breaks at one time or another; they are mechanical devices. If properly maintained, you can make anything last. Just keep in mind, gm parts and labor = inexpensive. Import pars and labor = insanely expensive. Its not uncommon to have a 1000 dollar brake job on an import, where the same job on a GM, Ford, Chry, would cost 200-300.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
BowlingSS
