What clutch for a LS1?
  • What clutch for a LS1?
    I'm asking this question for my brother. He has a 99 Z28 and has all the boltons plus cam, subframe connectors and will probably add more traction mods. I forget the dyno numbers of his car but it is making very good torque and hp I'm guessing around a low 12 second car he hasn't gotten to run it yet. The stock clutch isn't holding up to the power and the car needs something that grabs better. This isn't a daily driver but he would like it to stay streetable. What do you guys recommend. He was looking at the Spec Stage 3. Is that a good clutch, is there any chatter, and how long can you expect one to last?
    THe SPEC 3 clutches hold up fairly well and that's what most LS1 Guys I know run. They're strong and seem to last a while as well
    pics and info
      Everyone I know of seems to be running the Spec Stage III. They say it takes a bit of getting used to for street driving because it's pretty much an on/off clutch in comparison to the stock, but no one has said it's not streetable. Everone I know with a Stage IV says to not get a IV unless yer building a drag only car.
      2¢
      2001 TA ~ 2000 TA ~ 95 TA - Sold ~ 87 FB - Buried in New Mexico ~ 86 FB - Sold
        The Textralia clutch seems to be the hot ticket right now. I've driven a SS with one in it and it holds great but has a stock-like engagement.
        They are $$$ though.
        www.textralia.com
          www.textralia.com
          Wow you weren't kidding about it costing a bit more. What makes them cost that much more?
            2¢
            Man, I gotta disagree. I have driven several LS1's with a SPEC stage III and they engage MUCH like stock. The ones I drove had no chatter and they definitely were not a off/on engagement. Most of the guys that post about the stage IV's even say they are very streetable. Plenty enough for a daily driver.
              Spec clutches are not highly regarded in my area - several club members have had them and have had many problems - from premature wear to "blowing up". Obviously this could be caused by a large number of things (ie installed incorrectly). Most of the guys in my club are huge fans of Cartek or Textralia - both a little more expensive.
                Well ya'll have heard my opinion on spec stage II clutches. Never again.
                  Well, I don't think it's a good idea to make a lifetime "set in concrete decision" based upon a single experience with a company. NOBOBDY is perfect and should not be judged as such. SPEC indeed had some production/material issues with their disk materials, but they have long been resolved with the x-pad. SPEC makes a great clutch. The Textralia just happens to be a little more street refined.
                    I respectfully disagree. Screw me once shame on you. Screw me twice shame on me. It cost me about $500 to fix their screw up. I might not have needed a flywheel ($400) but everyone said it was the flywheel because I had it Blanchard ground. Turns out it was the clutch disc. There goes another $100 for a new one because I can't wait to send mine back, have them inspect it and send me a new one which is Specs return policy. It's a daily driver and they wouldn't send me another one while they inspected the bad one. I understand them wanting to do that but if it's a daily driver you can't. Koni knows this so they sent me a new shock They took my credit card number to send me a new one and gave me a month to ship the bad one back. They never charge me. I didn't loose the use of my car like I would have with Spec's method. I don't like the way Spec did business so I will take mine elsewhere.
                      Buddy of mine with a 99 SS was running mid/high 10's, 126MPH, 1.5x 60-fts on a RAM Clutch (402pp, 6130disk, 1550flywheel)...... took a hell of a beating with no problems.
                        Don't get me wrong, I hear ya. I know it sucks to experience "not so good" customer service, but I have just found in life that it's not wise to form an opinion of an entire operation based upon 1 or 2 peoples inability to provide great service to the customer. Many of these larger companies do not incorporate micro-management. This makes it more difficult to keep every single employee under the microscope... you know.
                        I guess all I'm saying is I've heard more good than bad regarding SPEC products and service.
