It is time to put the puzzle back together. Some things go right, some go wrong. I will try to note sometings that might be important to others who do some similar mods.
Wrong Part: ARP does not make a rocker arm stud that is a drop in replacement for LT1 w/ SA rockers. I got PN 234-7201 and found that these would only work with guideplates (or maybe a thick washer). I do not see catalog PN that has short enough threads on the head side. I will be re-using the original studs.
Right Parts: From internet forum info, I was thinking that the SA rockers I got would not work with the LE2 set-up (not enough valve stem above the lock). I am happy to report that there is .020 clearance with the LT-4 rocker.
?: I am very hesitant to install the brand new lifters I bought. The rollers were very stiff (binding) right out of the box. I went ahead and soaked them in oil and it helped significantly. They are still not that smooth rolling. Should I put the project on hold and see if I can still get these replaced?
I am pretty sure the setup I chose would not be recommended by those who are more knowledgable than me
