More stuff for car
  • More stuff for car
    Because the old torque arm mount ripped off the casing I went ahead and bought BMR's new torque arm relocation bracket and also a new pinion seal. That torque arm was a pain to put on because I broke the mounting stud on the trans mount which was easy to replace, stripped to of the new torque arm mount bolts out, and it was Freeeezing. I tried to warm up the garage with a portbale heater but it barley made a difference. Pushing that Bushing onto the torque arm was another story.
    Anyways I finished it up this morning before handing in my English portfolio and the car runs strong. We still have to fix that darn exhaust leak and the rattle that started after we installed the headers.
    Also, I think the 275's are to big in the front because when i pull out in reverse with the tires turned sharply it feels like it will hop in the front, like once or twice??
    What do you mean by "hop"? Does it feel like the tires are dragging, rather than turning?
    There are so many of us running 275's in the front without that kind of a problem, that I doubt its because the tires are too big.
      I'm running 285's in front, no problem.
        Ditto..... on several cars too. No problems.
          I can only notice it when I turn sharply and going very slow, I hear a thud and it feels like the front shifts. I checked the whole front and every thing looks perfect, no rub marks or anything, the frame rails, shock arm, all that stuff looks perfect. I also had an alignment last year. Theres no problems while driving though.
            How many miles are on it? I wonder if it could be a control arm bushing.
              It's not the tires, it's probably a bad ball joint or tie rod end. Check your sway bar end links and the bushings also.
                Change the rear end fluid and put in a couple bottles of the GM additive. See if that helps. I had the same problem and thought it was the front tires rubbing or skipping, but all that went away when I put some conventional oil in the rear diff & 2 $7.00bottles of the GM stuff. Now it turns real smooth, or at least it would, if the engine was still in it If you have a stock 10 bolt, you might only need one bottle.
                  Just so you know you're not crazy. The same thing happened to my 96 Z28. Only when in reverse with the wheel turned all the way to the right. Kind of a slight thunk... pause...thunk...pause...etc. Mine sounded like it was coming from the front. But I was running Redline Synthetic in the differential. Redline said I didn't need the slip additive.
                  Sold my car...it wasn't a big problem, but never had the time to narrow it down. I was running 255 tires...so that's definitely not it.
                  Joe K.
                  '11 BMW 328i
                  '10 Matrix S AWD
                    Alrite Im going to add some more additive into it next week, I'll also check the bushings in the front and the ball joints. Thanks guys
                      Added the additive tonight and that bumping is gone! Thanks for all the advice guys!
