Well, I found out what was causing the P0336 Crankshaft Sensor Code......It was the timing chain. Last night driving home from work, it broke, but not completely. A piece of the chain must have been hanging off and was slapping the inside of the timing cover. So I shut it down and had it towed home.
But at least I know EXACTLY what it is now.....
The entire ignition system is new. The Water Pump is new. But, what else should I replace while I'm in there?
I know that I have to take the motor off the mounts and jack it up a few inches to get the oil pan off. If I'm using a motor hoist, where do I hook it up to jack the motor up?
But, you don't have to touch the motor mounts. Just unbolt the pan and let it rest on the k-member.
