I have a 2002 Camaro Z28 w/ 45K miles and my belt is sqeeking like crazy. I put a ton of belt sqeek stuff on it and it only worked for the first time i ran the car and then came right back. Any ideas or what i can do to stop it????
Belt Sqeek!
Yes. Get a Goodyear Gatorback belt. Throw out the belt dressing stuff.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
make sure both of ur belt tensioners are working(pull them back and slowly relase them to see if the return to where they were) i think the LS1s have 2. i think the smaller one(a/c) is slide to tighten(pushes a pulley against the belt) make sure they are both tight(1" of deflection with fingure pressure) if that all checks out, u could get a goodyear belt but i've had good and back luck with those belts(2 of cracked within 4K, 2 others made nose). if u got the money get a manufacture belt2009 Honda Civic EX- the daily beater
I agree with Joe. I don't have a LS1, but I had tons of belt squeak, esp with the A/C running. Turns out the belt was stretched (only had 20k on it). Once replaced and pulleys cleaned, the squeal was gone.94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Get a new belt.1995 Z28 Convertible, 350ci LT1 73K miles M6.
You've got your answer... new belt... my firebird's a little older than your camaro.. but it was doing the same thing a while back and the belt just needed to be changed.... I just want to comment on the technical terms being used in this thread!!!Originally posted by 1994BlackFormulabelt sqeek stuff
haha
'07 Black Tahoe LTZ (my new baby)
'96 White Firebird (sold
simple green and a toothbrush.Originally posted by 1994BlackFormulahow do you clean the pulleys?
lather, rinse, repeat.Tracy
Also, if any of your accessories is getting old (alternator, compressor, power steering pump, etc), they can become harder to turn. The pulley would spin slower than the rest of your accessories and that could be your squeal. I know your car is low mileage but just the age (as opposed to mileage) of something can contribute to small problems like that too.
