I just got this 1995 firebird.It has a LT1 350 and auto trans.When you start to give it gas it cuts out and pops but after you drive it for a few miles it runs great and does not act up any more until you turn the car off and take off again.It does it every time you start the car.Could it be a fuel filter.
1995 firebird cuts out and pops on start up
tabahr
Does the SES light come on? Does the PCM have any stored codes? Also using a scanner to look at the sensor outputs in real time might give you an answer. I would guess fuel filter probs would be more apparent at high RPMs as a stagger or a cut off. At idle the engine is using very little gas.
This could be an open -VS- closed loop problem.
I don't think anybody is posting anything because they don't know what is wrong.
My first thought was a sticking fuel injector but I would think that might set off a SES light from a lean/rich condition.
I'm leaning to a spark problem since it doesn't seem to set the SES light off. With all of my problems with the OPTI spark section and all that I have seen on this board, that is my next "guess".
I don't know enough to diagnosis this problem. Let's see if this sparks a few comments.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
firebird update
I sent you a pm.Originally posted by Bojangles1432
I have a stock mass air flow sensor from a 94 z28, it doesnt have the little screen but all the rest is there.
I have no use for it just tell me and ill ship it to you.
The mass air flow sensor is bad on my car.I borrowed one and my car ran great with it.Thanks for all of the help.
olly402003
